11-19-2005 01:54 AM
11-19-2005 09:40 AM
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.11-20-2005 05:21 AM
11-30-2005 04:05 AM
11-30-2005 05:12 AM
01-15-2007 11:22 PM
hello, from the above vi, i have tried that it works for saving the filename with the time and date. but if the table is wanted to be saved, how would this vi likely to be changed?here i attach the vi with data from the table to be saved in the spreadsheet. how would this vi to be changed if no prompt message to appear?every time this vi runs, there is no prompt message to ask user to key in the file name. i know it can be done by using write lvm vi. but it is supposed not to be the correct vi, am i right?
thanks
pls help
regards
