I need some help with graphs
Can anyone help me out? I would like to have different labeled Y axis's.
What I mean is I would like to see Tempeture on the left side of the graph,
say 0 to 300 Kelvin and Pressure on the right side of the graph (O mabr to
1x10-5mbar). Both of these would both share the same x value, time.
I haven't been able to figure out how to do this or if this is even possible.
I don't want to have 2 different graphs side by side. Does anyone know if
this is possible and if so how? Thanks for your time!
Greg
(2,991 Views)
The easiest way is to upgrade to LabVIEW 6. For other versions, refer
to the LabVIEW FAQ at www.icon-tech.com.au/thelabviewfaq.html
(2,991 Views)
LabVIEW 6i is definitely the easiest way to go here--the dual-Y axis
functionality is built-in for the first time, and the vertical text
option makes it easier to label Y axes.
If 6i isn't an option, my favorite way to simulate a second Y axis in
5 and earlier is to use a customized "Simple Vertical Slide" control
(attached). Drop a slider on your panel and choose Edit>>Edit
Control. In the editor, move the slider housing box to the left of
the scale, the scale numbers to the right of the scale, and
left-justify the numbers. Back on the diagram, paint the arrows and
the slider transparent, hide the label, and then position the
resulting control on the right-hand side of the graph to make a
nice-looking second Y axis.
The trick to using this second axis is to pro
grammatically scale
(multiply) your pressure plot values to fit within the range of the
left-hand temperature axis. Then, using an attribute node, you can
modify the min and max values of your custom slider control/second Y
axis to indicate the real range of your pressure plot.
John Lum
(2,991 Views)
