I need to connect 5-10 points in an XY Graph, but not with a straight line.
It should be a line going THROUGH all the points, but having a smooth curve (See attached illustration!) Is this possible?
(2,746 Views)
You might want to look at the curve fitting fucntions such as spline in the mathematics>curve fitting palette.
(2,746 Views)
Thank you! I implemented Spline Interpolation and the result turned out to be EXACTLY what I was looking for.
(2,746 Views)
