I need to convert csv file to 4-20 mA signal with CFP
Good Morning:
I am lookng for some direction (architecture and VI wise). I have a CSV file that is generated by an analyzer thay posts 8 discrete numerical values. I need to open that file, (I think) drop the values into an array, pull out the required values, convert the value into a 4 to 20 number, then send it to a compact filed point unit with a 4-20 mA output card. After 5 minutes, I will need to repeat the exact operation again.
Any suggestions, concepts, ideas bits of code would be much appreciated.
SIg.
(2,885 Views)
How about a timed while loop with 5 (minus some poll time) minute intervals.
Poll the last 10-15 seconds for the csv file to arrive, do your extraction and send it to the Fieldpoint unit.
Thats it, I think unless there are requirements that you didn't specify.
André
André (CLA, CLED)
(2,867 Views)
(2,851 Views)
