I need to convert from radians to degrees?
Hi, I am creating a sine wave using the sine.vi under numeric/trig functions/sine. That function computes sin(x) where x is in radians. Is there anyway that I can convert this to degrees. Attach to this note is the code, if anybody wants to look at it to understand better what I am trying to ask. Thanks.
(13,486 Views)
lizherr98;
I looked at your code, but was unable to figure out what you want to accomplish.
To convert degrees to radians, just use the relationship: radians/pi = degress/180
Check the help files for examples included with LabVIEW. There are examples about using the sine function. I attached VIs as examples too.
Regards;
Enrique
www.vartortech.com
(13,486 Views)
In other words, instead of defining the input to the sin(x) function in radians, you want to specify it in degrees.
To convert degrees into radians multiply the input by pi/180 or approximatly 0.0175.
In case you're curious, to convert radians abck into degrees multiply the value by 180/pi or approximatly 57.30.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(13,486 Views)
