I need to export tables to an existing Excel file, how is that done?
The example vi exports a table to a new Excel file that is opened using some programmatic approach that I am not familiar with.  Familiar or not, it opens a new excel spreadsheet, and I need to open an existing spreadsheet.  I need to be able to export more than one table, but I think that I can figure out the placement of the tables within the spreadsheet.  Bottom line, how do I open an existing Excel file to export tables to?  Is there any (intuitive) information on how to do this?
JRyan
(2,553 Views)
If you start from the example and just replace the vi "open workbook" (that creates a new file) by the vi "open specfic workbook" (that opens the pointed file).
You will find this vi in :
    C:\Program Files\National Instruments\LabVIEW 7.1\examples\comm\ExcelExamples.llb\Open Specific WorkBook.vi
Then wire a file path transformed into string and there you are.
Hope this helps 😉
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,547 Views)
The examples help out a lot.  I assume you are referring to ActiveX as the unfamiliar.  Check out: http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&1744411D9B6C5820862567C2006DC236 for some good documentation on ActiveX.
Best of luck!
Travis M
LabVIEW R&D
(2,534 Views)
