I need to install LabVIEW Run-Time Engine
I Just got the LabVIEW application builder (6.1). I've built my first applicaion with an installer, but a pop up menu comes up that says:
"Remember that the LabVIEW Run-time Engine 6.1 must be installed on any machine that is going to run this application".
Can anyone please shed any light onto this?
Where do i get the LabVIEW Run-time Engine 6.1?
And can I add it to the disk being created so that it installs automatically when installing the labview program?
(3,372 Views)
Thanks, just found information on this. Will add the file containing the infirmation later
(3,373 Views)
Runtime engines for all recent LV versions can be found at:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C130D?opendocument&node=132070_US
Or FTP at:
ftp://ftp.ni.com/support/labview/runtime/windows/.
I'm not sure you would want the Runtime engine to install automatically when installing the program though...what if you want to reinstall the program?
Kim
(3,372 Views)
I have a built application that I update regularly. I always include the Runtime Engine in the installation. If it's already there the installer just checks to make sure it's a good installation. Re-installing isn't a problem.
Kelly
(3,372 Views)
