I need to load several different avi files, and then play them back simultaneously at the end of the program
Thanks SachaE for the media player driver....but how can I modify this so that I can load several files (individually or as an array) and then be able to play them simultaneously at the end?
Thanks again,
Dan
(2,713 Views)
If you are wanting to play the files simultaneously, you will probably need to incorporate multi-threading, making sure that each avi file is being played on a separate thread. Otherwise, the files real play very choppily. You should probably make a subVI that plays the file, make it reentrant, and then call it multiple times on different threads.
J.R. Allen
(2,713 Views)
