I need to modify an FPGA.vi that has already been deployed on a cRIO and runs at start-up.
Hi John, You should be able open the vi's under the compactRIO in your project to be able to run them; However you may need to rework any fieldpoint specific functions inside of those vi's
Also you may need the fieldpoint driver:
http://sine.ni.com/psp/app/doc/p/id/psp-855/lang/en
Joe Daily
may the G be with you ....
Message 21 of 33
(1,285 Views)
Wow!  That was a quick response!  Thank you Joe!  Have a good weekend!  John
Message 22 of 33
(1,278 Views)
Hi Joe,
Happy Monday!  I'm stuck on configuring FieldPoint to run on my system.  I installed the drivers you told me to and I see FieldPoint 6.0.5 from Start Menu > All Programs >Nation Instruments now but it looks like I can't import FieldPoint configuration files into LV Projects yet until I configure MAX.  I have attached a word document screenshot of my project explorer window.  I'm not sure what to do next.  John
Message 23 of 33
(1,251 Views)
Hi John,
You should be able to directly open the vi's without the project to see what is going on in them. Try this and let me know how it works out.
Joe Daily
Message 24 of 33
(1,235 Views)
Hi Joe,
Actually the vi's seem to be working fine but they (or the project) is not working as advertised.  If I disconnect the ethernet cable I am still getting error messages and I am not able to reconnect to the cRIO w/o at least closing the program and restarting it.  We will need to run all our programs from startup so I will need to build executables and installers.  Will that take care of some of the 'lost connection' error messages I have been getting??  I have heard error messages that occur during development don't necessarily occur after an executable is created.   I plan to try that out next.  - Regards, John
Message 25 of 33
(1,219 Views)
Hi John,
Would you like me to make you a good heartbeat example?
Joe Daily
Message 26 of 33
(1,212 Views)
Actually, that would be great!  Thank you for offering.  John
Message 27 of 33
(1,208 Views)
Hi John,
Sorry for the late reply but here is an example of a heartbeat.
You will notice that there are two timed loops. The top one is the server that sends the heartbeat. The heartbeat is just a simple boolean that sends a squarewave that changes every 1000ms (this can go as fast as 20 ms).
The second loop is on the client and detects the consistent change from the server if the change is detected that counter is reset, if not the counter is increased by one. Once the counter reaches a certain value the psuedo watchdog engauges and runs your failover code. In this case, it is just a string output.
Hope this helps
17575i7F50977548B4D02E
Joe Daily
Message 28 of 33
(1,169 Views)
Hi Joe,
Your example may come in handy.  Can you tell me what's going on in the true cases of the Case Stuctures? My customer has come up with another solution and it will be interesting to compare the two!  thanks again,  John
Message 29 of 33
(1,164 Views)
so the first case structure (under left) checks to see if the signal has changed. If so (true) the counter resets, if not (false) the counter increments.
The second case stucture (lower right) checks to to see if the counter goes about a cricital theshold if so (true) a warning is generated if not (false) all is well.
The code is a vi snippet so you can save and drag and drop the file into a block diagram.
Please let me know how this turns out
Joe Daily
Message 30 of 33
(1,159 Views)
