I need to perform a union of two arrays to see what are the common items in both
I need to find the items that are common in two separate arrays.  Is there a union operator for arrays or an intersection operator?  The example on the forums is written in an older version of labview and I cant open it.
Message 1 of 14
(5,991 Views)
Link to the old example?
Message 2 of 14
(5,977 Views)
Why in the world would you want to compute the union?  The union will merge the two arrays into one and lose any information about which elements existed in the two original sets.  That won't help you find out what was common to both at all.  You're on the right track with the intersection.  THAT is what you want to compute.
Here's an example from LAVA assuming your arrays are pre-sorted: https://lavag.org/topic/13187-computing-array-intersections/
I'm guessing this is the example you're referencing: http://www.ni.com/example/28766/en/
If so, post it in the version conversion forums and I'm sure someone will take the time to help you convert it.  I don't have 8 installed on this computer so I'd be useless in converting it if this is the example you're talking about.  If not, give it a try.
Message 3 of 14
(5,964 Views)
In any case, this seems like quite a trivial task?
What is the datatype of the arrays?
Are there possibly duplicate elements?
Should the output be a sorted array of the common elements?
How big are the arrays?
What have you tried? Seems like a good exercise. 😄
Message 4 of 14
(5,932 Views)
There are many ways to do this. One easy solution would use variant attriibutes, e.g. as follows:
Message 5 of 14
(5,916 Views)
That, Christian, is why you are a Knight of NI!  A very elegant solution, but I suspect the Original Poster is a student just learning LabVIEW and wanting to learn how Arrays work.  I must confess when I read "One easy solution would use variant attriibutes", my reaction was "What??!!" -- it is certainly something that wouldn't occur to me right away!
Bob Schor
Message 6 of 14
(5,893 Views)
Thank you sir.I was looking for a compact codefunction like this arrangement. I was wondering if it was hidden in an add on toolkit oe something that I hadnt enabled.
Message 7 of 14
(5,858 Views)
Just plain LabVIEW, no toolkit. Wrap it in a subVI if you like.
Message 8 of 14
(5,822 Views)
sir can you tell me how u combined 2 auto-indexing in the for loop together
looks like string will b inserted in the array only if boolean auto-indexing is true
im using LabVIEW 2010
Message 9 of 14
(5,796 Views)
You can use the search 1D array fucntion and a for loop
Regards
Abraham Kurien
CLD
Captronic Systems
Message 10 of 14
(5,788 Views)
