I need to plot dates on the X axis and numeric values on the y axis
I have an Excel spreadsheet with the 1st column being a part number, the next column being a date ie.. 06/30/2004, and the third column being a numeric vale. I need to parse the values for the date and numeric value using the part number, for a graph or chart.
How do I convert the date values on the X axis so they will display properly?
(3,015 Views)
Ok I think this would be easy could you post a sample file of this>
(3,015 Views)
Here is what I have so far.
(3,015 Views)
See if that could help !
Julien
(3,015 Views)
Well I played around with your code two parts where missing but I think this might work.
(3,015 Views)
Thanks I used some of the code that was in the vi and modified it to work in my vi.
(3,015 Views)
