It's hard to give more specifics without more detail, but in general you're going to need to read in the entire file, split it into three pieces (everything before the record of interest, the record itself, and everything after the record of interest), modify the record, reassemble the three pieces in proper order, and write the whole thing back to the file.Of course if the file is very large you might not want to actually implement it this way, but conceptually at least, this is what you are looking at.If this file some sort of proprietary format?Mike...PS: this type of issue is why I really like databases...
