I need to use agilent34970A with serial cable;but i'm not able to build a routine.
Hi, i'm learning labview and i'm not able to build a routine to communicate with my Agilent34970A with serial cable only and to use the data. Anyone can help me? thanks. lucky
(2,667 Views)
Are you using the driver from the LabVIEW Instrument Driver CD or that you downloaded from here? If you are, what problems are you having? Are there error codes generated and what are they? Have you verified that the serial cable is correct and the the comm parameters (baud rate, stop bits, etc.) are the same in the program and the instrument?
(2,666 Views)
Due to system changes, this instrument driver can now be found here.
(2,551 Views)
