I need to write a simple log file
I have a FOR loop, and for each iteration of the for loop I want to write to a line to a text file with the time stamp and the iteration number. The test I am doing needs to run through 5500 cycles, and I want to know how many iterations were run in case the computer crashes before the test finished. All I want to for each iteration to write the iteration number and maybe the date and time.
I've looked through the examples and I couldn't find what I needed.
(2,918 Views)
Hi Lars,
use the FormatIntoFile function with a proper format string.
And look at the examples coming with LabVIEW, they also explain how to use file functions in general…
(You just need OpenFile, FormatIntoFile and CloseFile.)
(2,916 Views)
