I need ur help plz
Hello
How  r u every body?
This is my first project .. and I am really looking 4 ur help .. I hop if I can find the answer.
(I am using lab view version 8.2)
very much Thanx
(3,140 Views)
Simply posting your assignment does not mean someone will do it for you, that defeats the purpose of an assignment. Take the time to go through the assignment and try it out, if you are completely new to labview, take a look through the Getting Started with Labview Guide and the Example finder. Once you have done your best to do the assignment, if you are still having problems, post specific question on the forum and someone will help you out. Simply posting your assignment and asking for someone to do it is not going to help you at all in the long run, and chances are if you were to simply hand in whatever solution you got here it would be some sort of violation of your school's policies.
do not however take this as a suggestion that you should not use the forum, it is probably one of the best ways to learn labview! Just make sure you are making the effort to learn on your own as well.
Jeff
Using Labview 7 Express
(3,125 Views)
I suggest searching the tutorials for some of the concepts in this assignment. You would be amazed at what your searches will turn up. About 75% of the time someone has already solved my problems. Not all in one spot, but it's out there!! You can do it, good luck.
Daddy-O
One should welcome adversity as an opportunity to excel.
(3,115 Views)
Mirage:
You and LuLu should team up and combine your efforts
http://forums.lavag.org/Help-me-t9451.html&gopid=38137#entry38137
(3,104 Views)
