I never used LabView but need to generate a RS-233 serial output string that contains an IRIG timestamp based on a contact closure. Is LabView an appropriate tool to do this? How much does it cost to get started with the product?
(2,616 Views)
Labview isn't cheap, but it would certainly allow you to build a program (set of vi's - virtual instruments) that would do what you describe. Where would the timecode information come from? Your vi, or program, would: Start up, initialize the serial port, loop until a trigger happened, read the timecode (from where?), output that timecode out the serial port in a loop until you pressed the stop button. There is a free evaluation of Labview software available from NI - the base product itself runs about $995.
- Dave
(2,616 Views)
