08-13-2003 05:14 PM
08-13-2003 05:56 PM
08-14-2003
08:16 AM
- last edited on
09-10-2026
08:21 AM
by
Content Cleaner
What version of LabVIEW and NI-DAQ are you using? Is it possible that you saved vi.lib DAQ VIs (such as AI Config or AI Start) into an LLB, and then ported them to another computer or a different version of LabVIEW?
Please refer to the following document Knowledge Base 15BHMK92: Error -10240 when Running LabVIEW-DAQ Application [link removed; article no longer available] for help on troubleshooting this issue. This document also contains a link to an example on removing vi.lib files from a hierarchy, directory, or LLB.
D. Putnam
08-14-2003 12:36 PM
08-14-2003 12:41 PM
10-24-2007 03:15 PM
10-25-2007
06:36 PM
- last edited on
09-10-2026
08:22 AM
by
Content Cleaner
Hi Topraka
The error message can generate by multiple reasons. Like Putnam said all this reasons are explained in the Knowledge base. I will strongly suggest finding the labview code of that executable and taking a look at it in this way you can follow the steps in this discussion forum: Get error 10240 in labview 6i Evaluation when I run my VI's from lv5.1 and take a look at this knowledge base: Why Do I Receive Error -10240 When Attempting To Run a LabVIEW Executable [link removed; article no longer available] so you have to make sure the NI-DAQ drivers you have in the directory with the exe are the same as the one in the labview directory where the executable was created. Can you try the same code in one of the other test machine?
I hope it helps
