I tried building with .EXE in 2023 Q3, but it force quits. A solution is needed.
I didn't try it in 2023 Q1 and Q2, and the build was successful in 2022 Q3. I tried using it, but the build failed in 2023 Q3. No errors are displayed. It just forces a shutdown.
I posted this article twice on the Korean community, but it was treated as spam both times.
We have a duty to know about this matter
If anyone has experienced the same problem as me and solved it, please suggest a solution to my problem.
(1,693 Views)
First, try building by enabling the "build log" switch in the Advanced menu.
(1,667 Views)
I checked the build log as you suggested, but the issue of forced termination remains the same
(1,606 Views)
Accepted by topic author RongTime
(1,584 Views)
And what do you see in the log file?
(1,578 Views)
덕분에 해결했다 고맙다
(1,545 Views)
