I tried to make a clock in labview 6.1 with fieldpoint hardware
I tried to make a clock in labview 6.1 with fieldpoint hardware. When i place a read or a another fieldpoint tag into it, the timer doesn't work anymore but remove i the tag then the timer works. Maybe i'm doing something wrong. I tried also to create a vi with this clock but it doesn't work, can someone help with this. The vi with the clock is an attachment.
TIA William
Running with Labview 6.1
Fieldpoint hardware
(2,642 Views)
Tia,
I would encourage you to make a smaller code as an example of what is not working, in that way you will probably get faster response and help on the problem in the discussion forum. Also, you could describe in more details what is not working, what is the behavior when it is not working.
I hope it helps
Andre Oliveira
(2,642 Views)
I made a clock in labview 6.1 with fieldpoint hardware and tags.
When i place a read or a another fieldpoint tag into it, the timer doesn't work anymore but remove i the tag then the timer works. See the samples, sorry for the size of the vi's
TIA William"
Fieldpoint hardware
(2,642 Views)
