I try to control cDAQ-9172' output to get series number.Maby arry is a good way.But,how do I do?
I try to control cDAQ-9172' output to get series number.Maby arry is a good way.firstly,I create a  array and enter 0,1,2,3,4,5,67,8.I try to get cDAQ-9172' output 0,1,2,3,4,5,67,8.But,how do I do?
(2,714 Views)
What module are you using in the cDAQ-9172 ? How are you reading the values to confirm they are sent correctly?
In the block diagram right click and go to  Measurement I/O>>NI-DAQmx. This tools pallet will have everything you need to communicate with your device.
Kyle K.
Product Manager for Product Data
(2,697 Views)
The model is NI9263
(2,689 Views)
Array manipulation is really a basic fundamental skill in programming - in LabVIEW or any other language. Have you taken the basic LabVIEW tutorial? Do you understand how a for loop will automatically index an array? Put the array outside the loop and place an indicator inside to see what happen. What about the Index Array function? Wire up your array to it with a control wired to the index input. Create an indicator and experiment.
(2,679 Views)
Thank you.I'll try.
(2,667 Views)
