I try to use the Windows Net send function over cmd.exe, only 77chars possible to send?
See VI below (7.1). I only can send 77 characters, if entering more no message is send, even no error is given out!
Someone an idea why?!
(4,010 Views)
Hi AVR!,
i can´t see the same behavior. But if i run your vi first it doesn´t work, so i have changed the red marked string constant (see the attachment). With this change a can send more than 77 characters.
Mike
(3,988 Views)
It's working fine now, thank you!
(3,962 Views)
