I uninstalled LabVIEW 6.1 from a Windows 2000 computer and now when I run DOS programs I get a pop-up error, "gpib-vdd.dll, An installable Virtual Device Driver failed Dll initialization". How do I correct this?
Occurs when running Edit.com for example. Error has choice to Close application or Ignore. If Ignore is chosen, application appears to run normally. Running repair of Windows 2000 does not correct the problem.
(2,809 Views)
Sorry, I'm new to this forum and did not take the time to explore the Knowledge Base. I found my answer at this link:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/86256a47004e16d186256acd0078478a?OpenDocument
(2,809 Views)
I'm glad you found it. Don't worry about the post. It's always good to check the KBs first, but we can't help it if we miss one sometime! The forum is definitely helpful though so don't feel hesitant to use it in the future. Good luck with the programming!
J.R. Allen
(2,809 Views)
