I use mathscript node in my LABVIEW program.why open the matlab program default every time when open the exe program that produced by LABVIEW
(1,618 Views)
What happens in the development environment? Are you sure you are using mathscript ant not matlab script? Can you show us some simplified code? Is this classic LabVIEW or NXG?
(1,576 Views)
Thanks @altenbach for your quick reply. It's my fault, i add a matlab script in another vi. It has no problem if only use mathscript node.
(1,469 Views)
