I've got wrong results with equation box
When I create equation in C programation in an equation box, the result is wrong. Are there number formats not to use in equation box
(3,028 Views)
Review the LabView help topics "Creating Formula Nodes" and "Formula Node Syntax". If you need more specific help than that, you'll need to post you VI or at least the contents of your formula node.
(3,028 Views)
Which version of LabVIEW?
> Thanks
(3,028 Views)
I've got the version 6.0
(3,028 Views)
What's the formula you entered?
(3,028 Views)
You should upgrade to 6.0.2. There was an issue with the formula node
and the way it parsed operators. Try rearranging the terms in your
statement. This was fixed in the maintenance upgrade.
(3,028 Views)
I finally find the problem. In fact when the equation box does an intermediaire operation with float terms, the result for the next intermediaire operation become an integer, so after many operation the end result is different.
I manage to have the right result, doing my operation outside the equation box.
Thanks for replies
(3,028 Views)
