I've successfully used CINs and compiled .lsb files with early versions of labview. However, the same compiler set does not work with LabVIEW 7.0. HELP!?
The directory .....\cintools\win32 no longer exists in
labview 7.0. I've changed the include directories and the custom build steps but a linker error still occurs.
(2,454 Views)
I have checked LabVIEW 6i, 6.1 and 7 and as best as I can tell there is no ..\cintools\win32 folder. Have you followed the steps in the Using External Code in LabVIEW manual? Setting change all the time.
(2,454 Views)
