I want the Programming pallet to appear whenever I right-click while in the block diagram
I want the Programming pallet to appear whenever I right-click while in the block diagram.  Right now I have to look at the Express dialog, arrow down and then click on Programming.  I want Programming to pop up first.  This has to be dirt simple but for some reason I'm not seeing the solution in Help.
(2,517 Views)
Accepted by topic author ahhah
go to tools...options...controls/functions palette...formatting
Select "Icons only" and "category(standard)".
Now right-click and pin the palette to get to the "customize" button. Select "Change visible palettes..." and click "select all".
see if this is better.
(2,511 Views)
In LV 2010:
Right-Click on the block diagram to get pallete.
Click on "Search" button.
Click on "Return" button.
You should now be in a mode where you can make changes.
Founding (and only) member of AUITA - the Anti UI Thread Association.
(2,510 Views)
This worked, thanks.
(2,506 Views)
This worked as well. Thanks.
(2,505 Views)
