I want to calibrate multi-axis-load cell.
Hi , I'm using NI cDAQ 9174 and NI 9237. I connected the multi-axis load cell. I want to calibrate separately for each axis. The example I'm currently using is continuous Measurement and Logging (NI-DAQmx), and what I modified here is the Physical Channel part of the Configuration Hardware part in the picture below. I checked well that the multi-axis data comes out when I run it in the main, but it's a result of calibration. I wonder how I can enter the mV/V value corresponding to each axis. If anyone can help, I'd greatly appreciate it.
(242 Views)
(234 Views)
I've had fun writing a calibration routine for inexpensive (and inherently "inaccurate") tri-axial accelerometer chips (I think I've posted about this in the LabVIEW Forum).  Never heard of a Load Cell until recently (also in the Forums), and the techniques/technology are "similar, but different".
I just typed "Calibrate multi-axis Load Cell" into a Search Engine, and found a lot of useful information out there, written by people who seem to know what they are talking about.  I recommend you do the same, especially since you know about the NI DAQ equipment you will be using, and how it interfaces with your load cell.
When/if you have a specific LabVIEW question about your implementation of the calibration procedure, come back here with a zipped attachment of the Calibration Project you are developing (preferably saved in LabVIEW 2021 or so, as many "experts" might not have the most recent versions installed).
Bob Schor
Bob Schor
(188 Views)
