I want to change the range of x-axis.
I am trying to retrieve the data from Citadel database which saves the values of sine function.
I want to plot the data on xy-graph but I only see a line as the range of x-axis cannot be adjusted. Is there any way to change the range of xy-graph?
(1,072 Views)
Right-click on the XY Graph >> X Scale >> Properties
Enable Autoscale or specify the range yourself.
https://tmesystems.net/
(1,061 Views)
