I want to compare the "screen brightness" of two images using a template image and an acquired image
Mostly looking for suggestions on the best way to go about this. Im trying to run a test that will allow me to compare the screen brightness of an LCD using a webcam. Essentially i will cycle power on the screen and every so often the screen will be incredibly dim. Im thinking i should be able to use the subtract feature with the two images and if i have a normal screen it should produce a close to 0 result, whereas the dim screen should give a non zero value (pixel wise) but so far have not been succesful.
(5,070 Views)
Can you elaborate on what type of equipment you are using and the outputs of this equipment?
-ncm
(5,054 Views)
I am using a logitech usb webcam, I actually managed to find a vi that solved my issue! Thanks for the quick response
(5,050 Views)
Glad you found the solution! 🙂
-ncm
(5,042 Views)
Help other people by telling what your solution is!
(5,036 Views)
Make sure your camera exposure settings are manual or your webcam will compensate for any kind of brightness variations you have!
Bill
CLD
(Mid-Level minion.)
(5,022 Views)
Accepted by topic author Jgarv743
http://zone.ni.com/reference/en-XX/help/370281AA-01/imaqvision/imaq_light_meter__point/  I used the rectangle version but this block instead of going with a subtraction! Being new to and self teaching labview i often overstep these easier solutions 🙂
(4,979 Views)
