I want to create a blinking tabpage
On command a certain tab-page should start blinking with a specified color. When a user clicks on the tab-page (or somewhere else on the tab) the page should stop blinking. I can't find a blinking option which the LED does have.
(3,112 Views)
I do not see a Blinking property for individual tab pages, however with LabVIEW 7 you can specify a different color for each Tab page. With a property node in a loop, you could alternate colors for the tab that needs to appear to blink.
Remember that Alliance Members are here to help. We do this stuff every day.
Daniel L. Press
PrimeTest Corp.
www.primetest.com
(3,112 Views)
Hi, thanks for the answer. I tried that option but then I have to put a delay in the loop which switches the 2 colors and that will give me problems with timing in the rest of my vi.
(3,112 Views)
You could have a separate while loop with its own timing to control the blinking of a tab control. You will have to come up with a cool way to control when it is blinking, but it is definitely possible.
(3,112 Views)
