I want to create a setting window , and where I can save the values
Sir
I want t create a setting
model in front panel. I want to
give some numeric value in
variables , these variables
should retain that  value .
when I will use these
variables later/after some
days in block diagram they
should retain these values .
(2,468 Views)
What have you tried so far?
Can you post your code ?
You may want to explain in more detail, what is your system doing exactly. Your description is  vague
The more information you can give the quicker we can help
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,463 Views)
Enter the desired number in the variable. Right click the numeric variable and select "Data Operations" --> "Make Current value default"...
Post if this is what you want.
Mathan
(2,461 Views)
