I want to create new files at interval of 2 seconds from "Write To Measurement File"
I am a LabVIEW beginner; I want to create new files (with similar names such as test_01.txt, test_02.txt ...) at interval of 2 seconds using "Write To Measurement File".
(3,590 Views)
Very good.
Bill
CLD
(Mid-Level minion.)
(3,587 Views)
Accepted by topic author taophyc7
You actually have to ask a question. Attach the program that you are having problems with. The subject had been discussed numerous times so you should have found examples when you did your search.
(3,582 Views)
This code will create 25 data files, one every 2 seconds.
Cheers
(3,559 Views)
Thanks !
I later went through some of the previous issues and solutions that have been proferred for them. It looked very easy after I did it but as a beginner, it was one of the hardest things to do.
(3,441 Views)
@taophyc7 wrote:
Thanks !
That's fine.  You're just having growing pains.  🙂
Bill
CLD
(Mid-Level minion.)
(3,408 Views)
