I want to detect if a file is locked by another program
I am using DBcad, an activeX component to implement a map in my application. During operation, it creates a database file to store graphic elements in.
If the database some how gets left open (or if another application is using the database) DBCad complains with a dialog that there is "No database". It doesn't, however, return a labview error.
Since I can't change the behavior of the OCX control, I need to create a wrapper that detects that the database is not accessible. When I use the LABView 'delete' function or the 'file/database info' function when the file is in use, I get a 'File not Found' error.
How can I tell the difference between the file really not existing and the file not being accessible?
I am using Windows XP/2000, not UNIX/Linux so I can't just look at the permissions
EDIT: Never mind. I figured it out already. OOPS
Message Edited by terminalman90 on 05-06-2005 04:31 PM
(2,564 Views)
Whenever you figure out the answer please post it so that other readers will know the answer.
Joe.
"NOTHING IS EVER EASY"
(2,556 Views)
@jhoskins wrote:
...post [your answer] so that other readers will know the answer.
Okay.
My solution is to make a 'wrapper' VI that takes the name of the database file. Since I am going to create a new database with the same name and I don't care about the previous content, I can safely delete the file. If the 'delete' function returns a file permission error (8), I know that the file is locked and I can either create a new name for the database or return an error (like the OCX *should* have done).
My mistake was that I forgot to include the '.dbf' extension so I was getting a 'file not found' (well, DUH) instead of the 'file permission' error like I was expecting.
(2,551 Views)
