I want to generate 200micro second delay. how to generate in labview.
(2,881 Views)
Use the "Wait Until Next ms Multiple Function" inside your loop.send 200 as a constant input.
(2,879 Views)
Dear Mahadev
As far as I know you can't. But it may be helpful to have a look of this link
http://forums.ni.com/ni/board/message?board.id=170&message.id=81398&requireLogin=False
regards.
 Bojan
(2,872 Views)
Hi i want a delay of 200micro seconds , so can u send me the VI?
(2,863 Views)
Be more polite in the forum, please.
Open the link in the post above and then see the post from Rolfk.
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
(2,856 Views)
What target are you using?  If it is Windows, Mac, or Linux, you cannot generate a 200µsec delay in software.  The multitasking nature of these operating systems makes any sort of timing with resolution better than about 20ms highly problematic.  However, many of the hardware I/O boards National Instruments (and other vendors) sells can generate such delays.  To help you accomplish this, we will need more information (what is your OS, what is your hardware, what is the delay being used for, how is it triggered, etc.).
If you are using FPGA as a target, a 200µsec delay is trivial.  Just use the delay VI at the appropriate point in your code.  RT is similar, although resolution and accuracy will depend on your target processor.
Note that you can use the high resolution timer on most modern processors from LabVIEW using a multitasking OS (use <vi.lib>\Utility\High Resolution Relative Seconds.vi).  This allows you to time things with high resolution, but the results are subject to a lot of jitter and must be treated with caution.
(2,838 Views)
