I want to generate a square signal (<1 KHz) what I can change the frequence during the execution of the VI
And what is your question?
(2,658 Views)
Are you using NI hardware? What is going to use the signal? There is a VI called squarewaveform.vi . It is found at functions >> waveform >> waveform generation >> squarewaveform.vi. It has a terminal for frequency. You will need to put this VI in a loop and generate small portions of the wave at a time so that you can vary the frequency.
(2,658 Views)
