I want to get signal waveform of pixel array image
Hello Everyone,
I am new member on NI community.
First I made a program to get the gray pixel array image in which I can vary the no of column and rows.
Second, I made a continuous waveform acquisition with DAQmx which can show the waveform.
I want to take hundreds pixel array images and their corresponding waveform signal at a time. I do not how to connect these program at a time or make a program which can operate for these two problems.
I would really appreciate for your kind help. Its been a long time that I am trying to tackle this problem.
Hope you get my point.
Here I attach program.
Thank you
(1,340 Views)
Accepted by topic author nazakatali7500
Hello, nazakatali7500. Do you want to combine these two VI in one, and make a synchronous acquisition?
(1,303 Views)
Hiii, First of all , thanks a lot for your response
yes, I want to combine these two VIs and make synchronous acquisition.
(1,272 Views)
