I want to know if Matlab must be installed on a target computer where a exe built from LabVIEW is installed.
Another way to ask my question: I have a LabVIEW created exe that calls M Scripts, and I send this to another computer where LabVIEW and Matlab are NOT installed, will the exe run?
Send answer to olga_V_koshhkina@seagate.com and to ed.mcconnell@ni.com
(2,614 Views)
Olga
You do need to have Matlab installed on the target computer if you want the exe to work. A similar analogy is if you use Excel in your program you must make sure Excel is installed on the target computer
Stuart
(2,614 Views)
