I want to log (4) 4-20ma signals to a PC inexpensively.
I have 4 4-20ma signals that I want to bring into a PC, graphically display in real time and historically log.  What is the cheapest way out of this?
Message 1 of 11
(7,133 Views)
I would get a USB-6000 series DAQ device and run the current through a 1% resistor of some value and record the voltage. I do not know os a cheaper way to do 4 at a time.
Joe.
"NOTHING IS EVER EASY"
Message 2 of 11
(7,124 Views)
Joe just beat me to to it. The cheapest is the one at https://www.ni.com/en-us/support/model.usb-6008.html. It even includes datalogger software so you don't have to purchase anything else.
Message 3 of 11
(7,119 Views)
Thanks for the stars dennis.
Message Edited by Jhoskins on 03-28-2006 11:14 AM
Joe.
Message 4 of 11
(7,116 Views)
This unit looks promising..thanks guys.
Message 5 of 11
(7,103 Views)
It is also extremely easy to use I have a couple of them . You can also check out easydaq and see what they have, they may me cheaper but I cannot vouch for there products because I have never used them.
Joe.
Message 6 of 11
(7,097 Views)
Please be aware that it's input impedance is a lowly 144Kohm, not your typical 10-100Gohm on traditional DAQ cards. So take this into account when you select your sense resistor so your results match expected values.
Message 7 of 11
(7,091 Views)
I have this worked out to the point where I exceed the distance recommended for USB.  Is there any way to communicate wireless to the datalogger.  The datalogger will be on a rollaround test cart that will be in a 50 x 50' lab.  Any ideas?
Message 8 of 11
(7,067 Views)
So what you are saying is that the PC could be anywhere but you want the USB-6009 to be stationary at the sensors correct.
Joe.
Message 9 of 11
(7,061 Views)
Here are some devices that let you extend USB connections with a CAT5 cable.
http://www.blackbox.com/Catalog/Detail.aspx?cid=308,1431,1432&mid=4911
http://www.blackbox.com/Catalog/Detail.aspx?cid=308,1431,1432&mid=3340
http://www.bb-elec.com/product_family.asp?FamilyId=100&TrailType=Sub&Trail=33
And a device that lets you put USB drops on your ethernet.
http://www.bb-elec.com/product.asp?SKU=ANYWHEREUSB/5
Message Edited by unclebump on 03-28-2006 03:37 PM
Message 10 of 11
(7,062 Views)
