I want to make a accumulate application
I want to make a accumulate application similar to OSC.
Attached file..... Someone made a accumulate application, it looks like OSC accumulation function. ( if we measured signal, some point( X axis ... Usually time domain) is same amplitude ( Y axis), so it's point represented another color. ex..  count > 1 is black..  count > 5 is yellow....  count >10 is red..
Maybe, if you can see the file, you can understand what I am saying...
I think maybe it used intensity graph....
How can I make accumulate function like to attached file?
Give me a solution,
Thanks.
Message 1 of 1
(2,407 Views)
