Dear Skegsy,
Fortunately, there is an example VI that does an excellent job of instructing one to use the custom control functionality to perform your desired action. To access these instructions, open LabVIEW, click [Help]>>[VI, Function, & How-To Help], search for "importing", select [graphics] under "importing", and click the link for "LabVIEW Custom Controls, Indicators, and Type Definitions". This link will open an Adobe Acrobat file with detailed instructions for your assistance.
I wrote (and attached) an example VI for you in which I customized one of the default LabVIEW boolean buttons to show an up arrow for the TRUE case and a down arrow for the FALSE case. I modified the Boolean button by right-clicking on the button from the Front Pa
nel, selecting [Advanced]>>[Customize...]. In the customize control window that now appears, you can modify any button using the help file instructions mentioned above.
Please note: the attached VIs may not function correctly in LabVIEW versions other than 7.0.
I hope this helps! Please don't hesitate to contact me if you need any further assistance. Have a great day!
Kind Regards,
Joe Des Rosier
