I want to measure above 100 points
Hello!
By Keithley 2400, I want to measure above 100 points. In my program, the poits that I can measure are only 100 points. How can I fix this problem? If you don't mind, could you modify my program?
(2,651 Views)
KUB,
It seems as if this is the third time you've asked the exact same question, and you never responded to the solution that was suggested the very first time you asked it. Do you understand that the person who answered you there (lesher) attached an image that shows a suggested solution?
You should go back to that original thread, examine the proposed solution, and--staying in that thread--ask a follow-up question (click the "Reply" button) if you do not understand something. If you do ask another question, you need to be very detailed and specific about what isn't working, or people won't be able to successfully help you.
Keep in mind that LabVIEW 6.0 (a fairly old version at this point) is really going to limit the number of people who can make modifications to your code and re-save it in a format that you can use.
John
(2,634 Views)
I am so sorry!
Thank you so much..
(2,630 Views)
