To use datasockets to publish data to be accessed via the web, see the following document.
http://digital.ni.com/public.nsf/websearch/F58A6C2DAAADECB68625672400636145?OpenDocument
This document explains how you can create an interactive Web page with which users can view data from a remote acquisition application without the common problems of a client-server application. You use the Measurement Studio DataSocket control and Microsoft Visual Basic to create a software component that you can insert in a Web page. You then use that Web page to read, write, or share data with other applications across the Internet.
If you want to publish data but do not want to write any code, you should consider the web publishing tool available in Labview 6.1. This tool allows
you to create a webpage to be published from the the LabVIEW webserver on your machine. See the following link for more information on ways to easily publish to the web from LabVIEW.
http://zone.ni.com/devzone/conceptd.nsf/webmain/E4E311FA046EE24586256B1F0074F39D?opendocument
As for starting the datasocket server when you run your VI, you can use the 'System Exec' VI to run the application. The exe to start the server is located in the following directory:
C:\Program Files\National Instruments\DataSocket\cwdss.exe
I hope this is helpful.
