I want to read data from excel to Labview
I am developing one application in which I want to read data from excel (specific sheet, row & column) to Labview.
Need your help.
(3,566 Views)
Hi punitladani,
use RGT (ReportGenerationToolkit) to read data from Excel.
To learn about the available functions examine the example VIs coming with LabVIEW!
(3,560 Views)
When you ask for help, try to provide as much information about your problem as possible.  If code, attach the VI.  If a "generic question" (as yours was), tell us about your LabVIEW environment (are you using LabVIEW 7?  LabVIEW 2015?  The Student Edition?  The Professional Edition?).
The Report Generation Toolkit, particularly the Object-based version released within the last 5-7 years, is the easiest way to read (and write) Excel, and can handle both .xls and .xlsx files.  Starting with LabVIEW 2015, it was included in the Professional Edition, but was an add-on for the other editions.
Bob Schor
(3,547 Views)
