I want to resize the window of the VI I'm calling...
This might be kind of a silly one ..
I'm calling a VI from the main program...
I go to VI properties...( from VI I'm calling) to make the resizing change...
However... This doesn't seem to resize the window of the VI I'm calling?
(1,519 Views)
you need a proper reference to that vi.  How are you launching that vi?  if you use Open VI Reference with the vi's target path, it should return a proper reference that you can use to open/run that vi as well as access its other properties.
(1,491 Views)
You need to change the size under VI Properties>Window Run-Time Position.
You might have changed the size under VI Properties>Window Size>Minimum Panel Size?
(1,453 Views)
Yes both posts explain an answer to my problem thank you.
(1,430 Views)
