I want to save the Acquired data from agilent
I am using Agilent 34972a for data acquisition and I have developed a model to save the data in the excel file but the data is not being saved.
May I know the issue in my programme.
(2,771 Views)
Does it ask you for a filename as your program is finishing running? Have you probed the data to see if there is anything there?
(2,729 Views)
I have been using teh HP/Agilent/Keysite 3497xA units for years and I am surprised your code works at all...
What you have here is a giant race condition
Your program is going to try to send all of these commands at the same time. Or if the VI's are not re-entrant the sub-vi's will run i a random order. basically BAD PROGRAMMING!!!
Here's one of my examples of how to properly configure and use this device
=== Engineer Ambiguously ===
(2,720 Views)
Thank you for your Answer.
I am new to programming for Agilent and LabVIEW can you give a suggestion to learn the skills for good programming like any tutorials or materials?
(2,618 Views)
yes, it asked for file location and it is saving only one value in one file. my problem is here i want to save all the values in only one file.
I don't know why it is happening like that?
(2,617 Views)
Look in the examples for the driver.  There should be something in there to create a Scan List.  This would include all of your channels.  Then a single read will make the 34972 take a measurement from each channel, resulting in an array of your data.  Autoindex on that and you will have a 2D array to save to your file.
(2,553 Views)
