I want to send the data on internet using my laptop as a hotspot of wifi ?
Dear Team,
I have created an I/O server & sucessfully made communication with Modbus RTU device.
Now I want to send this data on an internet.
I have a laptop, which i have made hotspot using connectify.
so i wish to transmit the data via wifi hot spot.
How to transmit the data via wifi from laptop ?
Can any one help me out on this...
(2,336 Views)
This is the easy part. Once you connect via the hotspot you can communicate using your standard internet protocols. Is the application accessing you laptop also running code you have written in
LV?
If so there are examples that show how to transfer data via a TCP/IP connection.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,324 Views)
