I want to sync multiple charts and their time bases on the display, how do I do this?
I am doing a hardware times aquisition and trying to display 4 charts that display the same time base. I would also like to adjust the time base divisions. My charts are seperated by index. I just want to see the same time intervals on each graph so that I can compare them. Your help is very much appreciated.
J
(2,680 Views)
You will need to set the Offset&Multiplier, XScale.Min, and XScale.Max to the same values for each chart. There is an example that comes with LabVIEW that does this for one chart. It is found under Help >> Examples >> Fundamentals >> Graphs & Charts >> Charts >> 'Real-Time Chart'
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,680 Views)
