I want to use the Pulse Generator function of the DT9816
Dear all,
I have board Data Translation DT9816 and there is signal generator Function in it, I want to generate a signal of 10 KHz
when i do it, with a software i am able to do it, but when i used the VI file from the LV Link Iibrary its gives error that some of the subVIs are missing and they could only be run at Version 4 of labview
Could any body tell me how can i generate a pulse signal from DT9816 Data Translation board ??
(2,873 Views)
Dear number,
two options come to my mind:
1) Ask the manufacturer for a more recent version of the device driver software...
2) Post the VIs in the Version Conversion Board and ask for a upconvert service. (Maybe someone else had the same problem before, so a little search may be useful too.)
(2,872 Views)
 I m using the following file and i m getting error in the error box as
DtLvLink.lvlib:Error Converter (ErrCode or Status).vi<ERR>
Invalid task
<b>Complete call chain:</b>
     DtLvLink.lvlib:Lvi Clock Settings.vi
     DtOLClock.vi
     DtOLWaveformGenerate.vi
could you please tell me what is the error ??
(2,869 Views)
Hi number,
I neither have that hardware nor the needed driver (and those subVIs) installed. I also cannot see the context in which the error occurs...
Did you create a task using the needed functions? Is the hardware installed correctly? Is the LabVIEW driver software installed correctly?
(2,864 Views)
