I want write data to TestStand from LavView and Read data from LabView to TestStand
as title
please tell me the good ways
thanks
(2,975 Views)
After installation, you should have a TestStand palette in LabVIEW. You'll see a bunch of TestStand Get/Set Property Value functions. Use these to read and write from TestStand variables. In TestStand, the variables are read/written by a Statement step or in a pre/post expression. There's a shipping example sequence called AccessingPropertiesAndVariables, that demonstrates the general idea.
(2,975 Views)
Dennis, The example you specified does not use LV.  Is there an example of LV getting properties from TS?
(2,674 Views)
The example I mentioned 7 years ago DOES use LabVIEW - assuming you open the sequence that is in the 'Using LabVIEW' folder.
(2,659 Views)
