I would like to convert resistance value, angle and voltage using bending sensor.
Nice to meet you.
It is the first post.
I'm sorry if I am rude because it is a beginner I do not understand manners etc. well.
We are using LabView 7 Express and SCB-100.
I would like to acquire angular and resistance information using a goniometer and bending sensor and then rewrite them to voltage, but I do not know how to do it.
Will someone please lend me your wisdom?
(3,236 Views)
Hi Yuki!
LabVIEW 7 Express is a discontinued version of LabVIEW, it was released all the way back in 2003. To adquire the data from those sensors I would recommed that (if possible) you get a more updated version of both LabVIEW and DAQmx.
If you're willing to continue with your current software, you would need first a version of Traditional DAQmx compatible with LabVIEW 7 Express. You can see the list here:
https://www.ni.com/en/support/documentation/compatibility/17/traditional-ni-daq--legacy--and-labview...
After that, you would need to acquire some DAQ hardware compatible with those drivers. You can see the compatible hardware for Traditional DAQmx 7.5 here:
https://download.ni.com/support/softlib/multifunction_daq/traditionalnidaq/7.4/readme.html#Software
Take in consideration that the SCB-100 is a a connector block, it is not designed to acquire data, which means that you need to get a different piece of hardware.
For further reference you can find the user manual for LabVIEW 7 Express:
http://www.ni.com/pdf/manuals/320999e.pdf
I hope it helps.
(3,191 Views)
